TwinTurbo.NET: Nissan 300ZX forum - I'd lean towards a caliper issue also.
itsa300zx
on September 12, 2023 at 11:56 AM
Need help with Stainless steel brake line problem
posted by doug8867
on September 11, 2023 at 11:28 AM
Only time I've experienced a failed hose was on a rubber type that degraded internally causing a check valve effect. Maybe remove the SS line and blow some air through it both ways.
doug8867
11:28:37 09/11/23
Sounds like a caliper issue. Did you rebuild them yourself?
ZaXxon
07:42:29 09/12/23
Thanks! I rebuilt them myself. Went very smoothly so I’m
doug8867
13:20:21 09/12/23
I still think its a sticky caliper piston and the heat is
itsa300zx
14:26:38 09/12/23
I agree, I think this is the most likely scenario. (n/m)
Polishzx
20:10:38 09/12/23
I don't remember any grease on the dust boot particularly
Polishzx
20:13:56 09/12/23
Thanks for the input guys. It’s looking like the grease may
doug8867
06:28:14 09/13/23
I'd lean towards a caliper issue also. -
itsa300zx
11:56:26 09/12/23
Thanks for the reply. See my reply above for more details. (n/m)
doug8867
13:21:06 09/12/23
Might be worth re-bleeding the entire system, just to see
Polishzx
20:17:55 09/12/23
Yeah, I did that last weekend. No change afterwards. (n/m)
doug8867
06:24:10 09/13/23
Caliper or pad install issue. (n/m)
23:29:31 09/27/23
